Getting Error 1067 Starting Service Failed On Your Device
I have an HP Windows 7 enabled laptop. The system architecture is 64-bit. I wanted to start a service in Server 2008, but I encountered error 1067 starting service failure. What should I do?
You can try any one of the methods given below.
1. You have to first what all services are running. Start the ‘service.msc’ an application that will help you know the running status of all the services. Close all unnecessary services and try to start your service once again.
2. You can also start the desired service from the command prompt. Open any command line tool like the CMD or Windows PowerShell. Type the command given below. StartServcie <service_name> <-Verbose>
