Getting “Error 2738” while installing Hallmark Card Studio 2012 Deluxe
Hi, I got an error message while installing Hallmark Card Studio 2012 Deluxe. When the installation process was almost 90 % finished according to the install bar, this error message is given below:
Error 2738. Could not access VBScript run time for custom action.
After that I clicked the ‘OK” button for finishing it immediately but again another message appeared that the wizard was interrupted before Hallmark Card Studio 2012 Deluxe could be completely installed. Then according to their instruction I tried to run setup again. I got the same error like before after trying again the setup procedure.
For your information, my PC is a Dell computer with 32 bit Windows Vista.
After a quick check I thought the program should work. But again there was an abnormal termination when I saved the card that I tried to create. Please help me to find solution.
