Hi, I am having a hard time in transferring songs to my MP3 player. I drag and drop them into my MP3 folder and that's what I've been doing ever since and never had trouble with it. Now I am getting error code Ox80070052. Any suggestions? Thanks.
Getting Error code Ox80070052 in transferring songs to MP3 player
Hello brett. The problem you are facing can be caused of many reasons. Some mp3 player has a limit in the number of files for its root directory. What you can do is to put files separately in different folders. Like for 100 songs make 2 or 3 folders and put them in it. Another reason could be the player is not formatted in NTFS. So you need to format it. Format you mp3 player in NTFS format and make sure you make backup of your files. Otherwise formatting will lose your all files. So keen that in mind. To format your player follow this; Open windows explorer > right click on the player and select format. Choose the NTFS option. Try the normal formatting. Do not choose quick format option. Hopefully this will solve your problem.
