Getting error everytime when I try to open the standard wsl file
Every time I try to open the standard wsl file, all I get is the message “IndexOutOfRangeExeption”. I use InfragisticStyleLibrary.wsl in conjunction with AppStylist for ASP.NET. The below file will explain more.
IndexOutOfRangeExeption error in progress dialog box
Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
index was outside the bounds of the array.
Details Continue Quit
The issue persisted even after I tried re-setting up the software. Can anyone help me out here? I do not have any idea on how to about.
Answered By 0 points N/A #137468
From your question I become to know that you are facing an error for using the standard wsl file. I think these problems make disturbance more.
You can use software to make it easier and get a good solve. You can use wsl file fixer and wsl file filter.
Software
After downloading this software you must install It. After open the exe file you should select your problem and click on “Fix Now”.
After that you need to remove all the past errors. You should click upon “Start scan”.
All past error will be removed.
