Getting an Error Message After Rebooting Ubuntu
Hello ,
I have been working on Ubuntu and after rebooting it I get an error message, and it continuously appearing after every few minutes. He are the screenshots of the messages:
Sorry, Ubuntu 12.04 has experienced an internal error. If you notice further problems, try restarting the computer.
I really need to know how I can fix this?
Answered By 5 points N/A #138932
You should see this type of problem when selecting show all button. Now I’ll show you how to disable this problem forever.
You should know that this version of operating system sometimes shows this kind of errors. But don’t worry so much. Please do the following steps:
1.       Following command should be run:
Sudo gedit/etcd/efault/apport
2.       Find the parameter enabled
3.       Go to its property
4.       The value of that parameter should say “1”
5.       Please make it zero and save it.
6.       Save  it
Restart the computer. Your problem should be gone by now.
Thanks for your time.
