casey cock
30 points
Posted on - 05/09/2012
I receive the following error message during the installation process: "An AJAX HTTP error occurred. HTTP Result Code: 500 Debugging information follows.
Path: https://www.techyv.com/ StatusText: Internal Server Error Response Text:
I need your help with this problem. Thanks in advance!
The installation has encountered an error.
Please continue to the error page
An Ajax HTTP error occurred.HTTP Result Code: 500 Debugging information follows.Path:http://opentest.byethost12.com/install.php/profile-openenterprise&locale-en&id-1&op-do status text internal server error response textÂ
Getting error message of AJAX HTTP error occurred. HTTP Result Code: 500
If this is the first time you encounter this error when installing it, abort the installation then restart the computer. After booting the system, try installing it again. If it fails again, check if your computer has an active internet connection. The installation requires an active internet connection because the setup wizard needs to download some files from the main server. Check your internet connection by visiting some websites with your web browser. Watch some online videos so you can check if you currently have a fast connection. If you have a bad connection I think you should try installing it again after a couple of hours or do the installation during off-peak hours so the connection is not congested.
If there’s no problem with your connection, try disabling your antivirus for the meantime until you finished the installation. But if this also doesn’t work, you may also try disabling your Windows Firewall then try installing it again. If this, too, doesn’t work, you should check the application’s system requirements to verify the compatibility of your machine with the application.
