Getting Error Message due to Hallmark Card Studio
I got an error message when I tried to open the Hallmark Card Studio 2011 after downloading it. The error message is given below:
CLR Error:80004005
I never got this kind of error before in years and I am really habituated to this software. Please anyone can tell me what is the reason behind of it and also I will be thankful if anyone comes up with the solution.
Answered By 20 points N/A #107697
Hi Adriel,
Do you have protection subscription in your computer. What kind of security program you have? There are some links that will help you in fixing the error CLR 80004005,
http://microsoft-support-squad.blogspot.com/2012/06/how-to-fix-computer-clr-error-80004005.html
And
https://www.techwalla.com/articles/how-to-fix-a-clr-error-in-a-computer
These links will helpful for you. I will also give you also a program that will eliminate spyware/malware and viruses. (Just an option, you can choose any antivirus that you like and used to) you can download this link: http://multi-av.thespykiller.co.uk
When you have already downloaded the links above, you can open, run it and save that on a disk. After the programs had been installed, just press the button scan/update. Let the tool fix the problem. I recommend you these links because it is not good to repair the problem alone. But if you are familiar with registry and have some knowledge in operating system then you can do it yourself, without downloading the links above by following these steps:
1. Remove any compatibility – right click on the application icon and uncheck the option “run this program”.
2. Uninstall .Net Framework in reverse order.
