Getting an error on Stencil Visio Antivirus.
I am trying to download the Visio Stencil program and it is being blocked by my antivirus program (McAfee). Is there a place or anyway I can download it without getting this problem?
Hello Nelson Carters,
I have understood that you are trying to download Visio Stencil program may be it is needed for you.
This downloading is disturbed or blocked by McAfee.
To continue or complete the download you have to follow following steps:
By following these steps you can download Visio Stencil program.
Programs and viruses same as viruses are too programmed but harmful. Viruses run automatically if it gets scooped. Anti viruses are programmed too and they also run automatically and spontaneously to protect your computer. You are running an antivirus and going to download another one that’s properties basically same with virus.
So your current antivirus blocked that. It is known to all anti viruses conflict with each others. So do not use multiple anti viruses at a time. If you feel that Visio Stencil program is better than collect it from others sources (friends, other PC) and uninstall the previous one.
If the program you are downloading is being blocked by your antivirus then it is best to stop downloading it because your antivirus found a problem with the file. One possible reason why it is being blocked is a possible malware infection. Disabling your antivirus just to be able to download the file is not a good idea because it will put your system in danger.
If you want to download visio stencils, try downloading this New Office Visio Stencil from Microsoft. It supports Windows Vista, Windows 7, Windows 8.x, and Windows 10. This download contains over 300 icons to help you create visual representations of Microsoft Office. Several of the icons represent server roles, server, applications, and services that you can use in architecture diagrams, posters, and charts.
