Getting error when updated computer BIOS from F.20 to F.21
I had updated my computer BIOS from F.20 to F.21. Since then I am getting some errors. Specially event 4 and 5. Now only event 13 is showing –
Error : Event 13, ACPI
The embedded controller (EC) did not respond within the specified timeout period. These indicate that there is an error in the EC hardware or firmware or that the BIOS are accessing the EC incorrectly. You should check with your computer manufacture for upgraded BIOS. In some situation, this error may cause the computer to function incorrectly.
Error:
Event 13,ACOI
General
: The embedded controller (EC) did not respond within the specified timeout period. This may indicate that there is an error in the EC hardware or firmware or that the BIOS is accessing the EC incorrectly. You should check with your computer manufacturer for an upgraded BIOS. In some situations , this error may cause the computer to function incorrectly.
Login Name: System
Source: ACPIÂ Â Logged:Â 30/11/2011 1:46:35 PM
Event ID: 13Â Â Task Category:None
Level: Error  Keywords: Classic
User:Â N/AÂ Â Computer: PT-Laptop
OpCode:Â Â
More Information: Event Log Online Help
