Getting error while accessing Microsoft Access 2010 file through Import Data task
Hi Experts,
Hi Experts,
Hello
You get that error due the incompatibility of the used platform from a previous version then you need to install a component to resolve it and to can access to the file, then how the message say you have to download the missing component and for that here is the link to download that missing installation of Microsoft Office 2010:
http://www.microsoft.com/en-us/download/details.aspx?id=23734
I hope that my advices will help you to get through your problem.
You may be missing some important Microsoft office components on your system that are required for it to work well.
In order to resolve the issue.
I will suggest that you run the windows update to install any components that are missing from your system for instance .Net framework that is required for the system to work.
Nicke
