Zubain19
Posted on - 08/10/2011
I am getting Error whenever I am trying to run any application in my PC. It says, "SQL Error : Install Microsoft Net framework". What do I do now? My PC is an rotten device now. Should I install a Antivirus program or what?
Help me out please. I use windows XP.
Jack034
Getting an error while running any program
.NET framework is an important part of many application. To run many application you need this program on Windows. It provides common functionality for applications(which need the net framework). It helps you to apply usual dexterity across many devices,applications and programming tasks. It also integrate with other tools and technologies.
It also helps to build compelling applications faster. It is known as common language runtime which provides an abstraction layer over the operating system. It also pre-built code for common low-level programming tasks. So, It is not a virus. So, download and install it.
You will get this from this link, http://www.microsoft.com/net/downloads To secure your PC from viruses, you should install an Antivirus like Norton, AVG or Kaspersky etc.
Please download from the following link. Download Link and install it onto your system. Many programs require Microsoft Net Framework while using Windows Operating Systems.
