Getting half blurred printed page from my printer
I have HP Laser Jet Pro 200 color Printer.The printer works fine in start but now when I print a page some portion of the page is blurred and rest of the page is not blurred and looks fine.Anyone can tell me is this a toner problem or there might be some issue in this new model ?
Best Answer by Gather Hydty
Answered By 0 points N/A #200035
Hi Adamswhitley,
If the what you described above is correct, this means you should check the paper type settings. Follow the simple steps listed below:
1. In the software program, choose Print option.
2. Choose the product, then press the Properties or Preferences button.
3. Press the Paper/Quality tab.
4. Press the More.. Option from the Paper Type drop-down list.
5. Extend the list Type is: options.
6. Extend each list of paper types and find the type you are using.
7. When you find the type you are using click the OK button.
I hope this helped.
Answered By 0 points N/A #200036
Hai
How are you,
This happens when the imaging drum has lost the life. You may try by replacing the Drum of the printer. Also there is blade in the printer, this also may cause the issue.
As the Laserjet printer is trouble free always, better consult with a Printer Tech.
