A. Meyers
15 points
Posted on - 07/30/2016
Hi. The speed of my internet is not up to the mark these days. I think that it is working very slowly these days. What are the steps to check how fast is my internet right now? Please reply ASAP. Thanks in advance.
By Getting To Know How Fast Is My Internet Right Now
Hi. The steps to check how fast is my internet right now are as follows-
1) Method-1: From the PC
• Ensure that your PC is connected to the internet first
• Click on the start menu
• In the space provided, type network
• Click on network option which appears
• To get the Internet speed, click on view status option
• If you are a Mac user, press command key+F
• Then, type activity monitor and double-click on it
• Then, click on network and get the speed of your Internet
2) Method-2: Using the InternetÂ
• Close all the applications first before you begin the Internet speed test
• Open the browser and type Internet speed test on it and press enter
•Use applications such as PC Pitstop to check the speed of your Internet
• While choosing the server, make sure you select the one which is nearest to your location
• Start checking the Internet speed to find out where exactly the problem lies
• If you think that you have a problem with the service, then call the number of the ISP which has been provided
Hope we helped.
