Getting the link to DevonThink in spite of uninstalling and reinstalling
Hello experts,
I still get the link to Devon Think occasionally, when I run click on a few items, in spite of uninstalling Devon Think, re-installing it and then uninstalling it again twice.
Also, I am using AppCleaner and AppZapper.
I have searched in Google and also maintained the uninstall commands given on a website in Internet, but still find the Devon Think link.
What is the problem? Please help me to solve it.
Thanks a lot.
Best Answer by Kimathi Raon
Answered By 0 points N/A #154400
Hi Gyle Kugler,
First of all delete the file and folders. The product. specific folder in-/library/application support/. And preferences files and if you have installed  The dashboard widget, book markets from your browser and extras which depending on Devon technologies. And just stand for your home folder. Try this ones and see  you problem will be solved.
Answered By 0 points N/A #154401
Hi Gyle,
One problem with using apps is that they make their page setup the homepage on your browser. To remove it, you just need to setup the homepage address again. I think you can do this easily. Just go to your browser options and edit "homepage address", then click OK.
