Getting an NSIS error when trying to run installation program
Hello all
I have been trying to install the GOM encoder using the GOM video converter installation file, but I get a NSIS error in the installation file.
The screenshot of the error is attached below:
The message states:
GOM ENCODER Setup
The installer you are trying to use is corrupted or incomplete. This could be the result of a damaged disk, a failed download or a virus.
You may want to contact the author of this installer to obtain a new copy.
It may be possible to skip this check using the /NCRC commend line switch
(NOT RECOMMENDED).
OK
Any help in this issue will be highly praised. Looking forward to your suggestions.
Kind regards.
