Getting Ntdll.dll Error Windows 7 OS At Shutdown
Hi, I got a message when shutting down my PC as ntdll.dll error windows 7 crashed files but my PC working a little fine. Give me a solution. Thanks in advance.
antdll.dll error may appear due to many reasons they may be a damaged or corrupted ntdll.dll itself, sometimes hardware drivers corruption takes place or issues between Windows and other programs. Restart your PC sometimes a temporary problem. Try to reinstall program if error displayed when you used a specific program.
Any updates or service packs available install them. Disable add-ons in browser one by one and figure-out source then remove it. Disable data execution prevention for Explorer.exe. Run memory test, is there any damage to HDD or RAM? This is a rare case. Try change IDE/SATA cable connected to HDD once.
