Getting Run-time Invalid Procedure Call;How To Fix?
While running the application is show an error code and then shuts down. To reopen it I need to reboot my system. Why am I getting such errors? How to fix it run-time invalid procedure call.
If this error code appears, then the application was closed due to some Internal error. This is often caused due to intervention of the security programs running in parallel. To fix the issue update your security software and check if there is any bug. If there is any then you can proceed to reinstall or repair.
Unfortunately, you did not indicate the name of the program. If the application constantly triggers a “runtime invalid procedure call” error whenever you start it, check if your computer meets the requirements. Sometimes programs check the target operating system before it gets installed to verify its compatibility. If it is being installed on an unsupported platform, setup will trigger an error then halting the entire installation process.
This method ensures that the application gets installed on the right operating systems. But there are also times programs don’t check compatibility during installation. This is when applications get installed on incorrect and incompatible operating systems. You will just know that the program is not compatible right after you install it the first time you run it because it never runs.
To fix the problem, visit the website where you downloaded it and check its system requirements. Verify that your computer is perfectly compatible. Also, make sure any prerequisite application components get installed first before installing the actual program.
Notifications
