Monroe9
Posted on - 09/09/2011
Today, I have installed fresh copy of my Windows XP with SP2. After installing all needed programs, I tried to open my internet browser – Firefox. But unfortunately, I got an error. Before, Firefox version 3 installer worked fine.
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: CProgram FilesMozilla Firefoxfirefox.exe
R6026
– pure virtual function call
                  OK
Getting runtime error on Firefox
Actually, the problem is due to system registry. You should have to download a registry repair to repair your system registry. You should download a registry booster and install it. Scan your computer with it. Fix all the issues, then clean your temporary internet files, then check your Mozilla Firefox if it's working. If it does not start working, then you should have to install the latest version of Firefox.
Hi!
Solution 01
Firefox run time error can occur because of the version you are using. If you are using an old version, just try to download latest version from Mozilla web site. Install it and try it out.
Solution 02
This might also occur when system registry is corrupted or deleted. Use a good Register cleaner. You can download some system registry cleaners and try them out. Be very careful when you are handling system registries. Better if you can go to an expert to fix it. System registry contains all the details of configuration of hardware, software, etc.
Visit this site: http://www.piriform.com/ccleaner
Solution 03
Not only that, check for the fault applications which you have in your computer. If you found any, please uninstall it.
Solution 04
Run a system scan and check for viruses, because this error might occur due to the virus effects. Just check out if you are having conflicts of the application in your computer.
