Getting started with the new Biztalk installed
I am a freelancer who wants to put everything needed for my Outsourcing work into place, I recently learnt of a business Process Management (BPM)  server and successfully installed it. After installing the 2010 labsVideos.zip 822.0. How can I get started right away? I have been trying without success please help me.
Answered By 0 points N/A #84736
If you are sure that your Biztalk Server is in place then the procedure is this, close the Biztalk Server documentation if it is open Download and run the Biztalk, Click unzip documentation files to the C:proramFilesmicrosoft Biztalk server 2010Documentation folder. While doing this make sure to specify the location name if you saved your documentation on a folder. Open Biztalk server, what to note is that the contents of the download should be placed in a Microsoft Biztalk server 2010 Documentation. This is if your download was successful and if  not then you have to download it again carefuly following the right procedure then follow the above procedure to get started. The advantage of Biztalk is that it requires no special softwares installed like many other serves.
