Getting startup error while accessing QOS
When I am trying access QOS for trimming the network and working with the Linux system to connect to the Cisco console. Every time I tried to open the QOS, I got an error related to the same application.
The error is as follows:
Links and More Information.
This error occurs when there is a problem reading the configuration file for the Web server or Web application. In some case the event logs may contain more information about what caused this error.
View more Information.
Answered By 0 points N/A #85765
This must be really annoying especially when you want to access your QOS urgently. I am not sure whether you have tried support, maintaining and testing your Linux drivers. The error shows that there was a problem with the configuration file for the web server may be you could consider testing you Linux server and continually maintain it using the latest version in the market.
Check that your login credentials are correct and not duplicated because this could cause a server error too. With the Linux server you need to always be on your toss seeking maintenance, testing and supporting to ensure it is always in a working condition. Try this to see which one will sort your problem.
