raver
Posted on - 11/02/2011
Lotus Notes UI Automation. I am running on SQL Server ’05 and using Lotus Notes 6.5 to 8.5.1. I am using Visual Basic 2008 to mechanize Lotus Notes UI to make e-mails in HTML. This contains a link to a website. For example, the link is “http://www.example.com/abc.asp?def=TRUE&Ref=123.” This works on Internet Explorer, but then I check the link in the sent items, “&Ref=123” changed to “&Ref%123” and the link does not work anymore. This happens to all of the hyperlinks. How do you stop this?
Getting trouble with my Lotus Notes UI Automation please help.
Hallo Raver,
The problem could be with how you are assigning or writing the links and therefore I will advise that you try changing them and see if they will work properly..
For instance, in the link you have given above you, I will suggest that you replace the equal sign symbol (=) with the American standard code information interchange character, 61, and see what the response will be. It should be able to work that way, after you replace the symbol with the number.
Hope this will help you out.
__
Regards
Mahesh Babu
