Getting UPDlib error 573 in Avira Antivirus premium
Hi!
We are employing Avira Antivirus premium on my laptop or computer. My PC has its own antivirus which updates automatically and it never ever allows virtually any mistake.
However, for approximately days to weeks in the past, it has started to give me a big job. Now every time Avira Computer virus premium try update, it presents UPDlib error 573.
I would be really glad if I will be told on what do i need to do today to resolve this concern?
Best Answer by Sollis Parallag
Answered By 45 points N/A #106379
Hello Adolfo.
Congratulations on your Avira Antivirus Premium.  It is one of the best antivirus software out there with excellent detection and removal.
Before trying anything, please try this first:
1. Uninstall Avira Antivirus by going to Start > Control Panel > Add or Remove Programs, selecting Avira Antivirus and clicking on Change/Remove.
2. Restart your computer to complete the removal process.
3. Reinstall your Avira Antivirus Premium.
If it does not solve your problem, I suggest getting in touch with Avira's tech support.  Since you have a Premium version, they should be able to help you resolve any issues you may have with their antivirus.
Answered By 590495 points N/A #106381
I think your Avira Antivirus probably encountered an internal error or maybe one of its components got corrupted. Try uninstalling and then reinstalling the antivirus program and see if it works. This will fix any corrupted files and restore its configurations back to default including some of the settings that you might have customized. If it does not work, you may want to check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like Norton SystemWorks or PC Tools Performance Toolkit.
You may also try upgrading your version of Avira Antivirus if the problem still persists.
