I am trying to use Rainlendar 2.5 build 76 but I am getting the warning message. Does anyone know what this error is or how to get around it? I really need your help so any help would be appreciated.
Thanks in advance.
Warning. Rainlendar 2
[12:43:50] Remember The Milk Error!
Server returned result: (18) 200 OK.
OK
Getting warning message while trying to use Rainlendar 2.5 build 76
It can be a code issues in RTM, try to connect time to time and see any anything changes. It would be nice to update the Rainlender to build 77. Also try deleting the finished tasks in RTM.
You can also try by disabling Rainlender service from RTM account and rebuild the calendar into Rainlender.
This operation would make Rainlender to make authentication token request from RTM, again.
When adding tasks on Rainlender, just check the firewall whether it’s set for allowing the traffic.
