I have a Netbook and I wanted to access the BIOS. I was able to access it and I did not change anything. Soon after that, when I turned on my Netbook, it constantly starts a repair loop. I can’t reinstall Windows since it doesn’t have an optical drive. Booting in safe mode has not helped either. Any suggestions?
Getting Windows 7 netbook repair loop
All you need to do to bypass this issue that you are having problems. And to use your laptop every time you want without stressing your self. If you have already tried safe mode and you said you can totally open your bios now. First step that you need to do is to get into your bios and choose LOAD OPTIMIZED DEFAULTS. THEN SAVE YOU SETTINGS. If this doesn't work for you. I have Another solution since you don't have an optical drive. Here is a site where you can repair your windows with just a USB drive. Use this link to fix your laptop by usb drive for USB drive repair on your laptop.
