Hello everybody I am a computer newbie and I would love to know the Safe Mode feature available in Windows seven or any other Windows. My friends say that Windows Safe Mode can be very useful for uninstalling any kind of irremovable software and it offers a fast feature of diagnosing windows problem. If so then I would like to know it. How do we get into safe mode? How to operate safe mode? And what are the disadvantages of it?
Getting into Windows Safe Mode
Below are the “How-to’s” to get various Operating systems started in Safe Mode.
Windows 7:
Reboot or Restart your computer
Just before the Windows 7 startup screen appears, press the F8 key on your keyboard
This will open the Advanced Boot Options
To enter Safe Mode, move the down arrow until Safe Mode is selected
Press Enter
Starting Windows in Safe Mode can be used when you can’t start Windows normally. This start mode will only use and start the most important Windows processes. You can easily troubleshoot or fix Windows errors from this window.
Windows XP:
Just before the Windows XP startup screen appears, press the F8 key on your keyboard
This will open the Windows Advanced Options Menu
Windows 8:
You can select to start your computer in Safe Mode from the startup settings menu.
Open the Advanced Startup Options menu
Click on Troubleshoot > Advanced Options > Startup Settings > Restart
Your computer will restart and there is no need to press any keys
The Startup Setting window will show on the screen automatically
Press the number on your keyboard that corresponds to Enable Safe Mode on the menu
In Windows 8, the Advanced Startup Options menu is the main area where you can fix the entire Operating System, for e.g. access diagnostics, you can reset your computer, you can do a system restore and Refresh your computer.
Windows Vista:
Just before the Windows Vista startup screen appears, press the F8 key on your keyboard
Disadvantages of using your computer in Safe Mode:
This startup method doesn’t use all the device drivers of your Operating System, so some hardware might not work if it needs specific drivers. It will also disable some autostart programs, so some programs might not start up automatically. Some programs or processes that rely on your graphics card features might also not work properly, as Safe Mode uses Standard VGA modes. Some drivers that are not started when you use Safe Mode might make your wireless or modem devices not work.
