Getting word count with Adobe reader on my PDF document
It’s very easy to do if you have adobe reader professional version by following the below steps:
1. Open the file using adobe reader professional.
2. From the “file” go to “save as”>”Microsoft word” then select “Word Document”.
3. Open the saved file in Microsoft word and check how many words you have.
Trienity Maria
Hi
There are many ways to do this
Option 01
· open the documents in Adobe Acrobat
· Select file
· Then select “Save As”
· In the Save as type select RFT format
· Click on the “save” button
· The open saved RFT documents in MS Word
· From the menu bar select “tools” & choose “Word Count”
Option 02
You can get online solution to count your words in PDF
Go to this link: http://felix-cat.com/tools/wordcount/
Option 03
Buy commercial software like “ANYCOUNT”
Thanks & Regards
Mckinney Ma
