Jerry Fox
20 points
Posted on - 10/14/2011
The following error message I am encountering now a days.
I am using latest DirectX and equipped with NVIDIA Graphics card.
If anybody know the proper reason why it happens and know the resolution, please let me know.
GfxUL.exe – Application Error
Application has generated an exception that could not be handled.
Process ID=0x7c0 (1984), Thread ID=0xdc (220)
Click OK to terminate the application.
Click CANCEL to debug the application.
OK Cancel
Thanks,
Jerry
GfxUL.exe – Application Error …
You are having a problem with your video card driver. You might have installed a different driver for your video card or a virus is stopping your graphics card to work properly.
Solution 1:
Uninstall the driver your installed and then download the most compatible driver for your current video card. It will fix the problem for you.
Solution 2:
Try repairing your operating system because there might be viruses that runs through the system that making the error on running your graphics card driver. But make sure to make a scan first on your system before doing this to make sure that it is not a virus related problem.
