Gifting A Handmade CD Label Where Can I Get CD Labels Printed?
You can either buy from an online store like flex print. In, or there are many websites available from where you can get customized labels easily.
Or you can create your own CD template if you want to buy it online you can go to the website, and you can get the CD template for approximate 50 rupees. You can select the quantity, design options according to the need.
If you want to design your own CV template you can do that with the help of MS Word templates.
If you want to design a label for your DVD, the best way to do it is to use a CD or DVD label maker such as the Acoustica CD/DVD Label Maker. The application allows you to create and design your own CD, DVD, CD jewel cases, and print directly to the disc if you have a supported CD printer or LightScribe drive.
It supports Windows 95, Windows 98, Windows NT, Windows 2000, Windows Millennium, Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10. It requires 400 MHz or faster Intel Pentium II or equivalent processor, 64 MB RAM, and printer. Among its features include:
