Hello friends,
I am using GIMP for my image retouching and editing. I had its version 2.x from GIMP 2.6.12 but now it’s creating a problem.
It crashes when I try to open it. The following error is seen on my screen:
GIMP Message
Low frequency even Message
Error while executing script-fu-LF-Even:
Error: ( : 1) Procedure execution of gimp-selection-layer-
alpha failed on invalid input arguments: Item “Background
copy” (8) cannot be used because it has not been added to an
image.
OK
I searched a lot for the problem and found I updated to version 2.7, but unfortunately this version is not compatible with the 64 bit version of GIMP.
Your guidance is required in this regard.
Thanks and have a good day.
Mark
GIMP Error – Low Frequency Even Message
Most time we face many types of problems one of these GIMP Error. So Download the most recent GIMP version 2. 6. 11.
It's more stable because it has many bug treatments since 2. 6. two.
Camel Case Is Capitalizing Each Word Of the Sentence, Just Like This particular. Just in case you do not understand what Rod indicates by capitals where they do not belong.
