Hi there,
This is the error when I want to open a PSD file with GIMP. Last time it worked just fine and it helped me very much. Can anyone tell me what I did wrong ? How can I repair this ?
Thank you !
GIMP Message
Paint Shop Pro image Message
Unsupported PSP file format version 5.0
GIMP Message
Opening ‘/Users/Desktop/NASCAR09/Logos/AssortPack-01/Ultimate Decal Sheet-1.psp’ failed: Paint Shop image plug-in could not open image.
points
GIMP error with paint shop pro image
Paint Shop Pro (PSP) file format is quite unfamiliar in the world of pictures and also, it isn’t supported by GIMP natively. Using the “Paint Shop Pro image plug-in”, you’re able to open some PSP files but not most of them because they might come with unknown data inside it that is unreadable by the plug-in.
In order to open the file, you can use any converter that will convert the file into a readable and popular one, for example, Image Converter Plus. Download Image Converter Plus.
