Ginormous iPad from Apple ?
How different is this new ginormous iPad from existing iPad 2 and what additional features does it have.
I want to know more information about this new iPad.
Hi Johnnie, the iPad is different from iPad2Â in many aspect like the processor, RAM, weight, internal memory, camera, HDMI, Bluetooth tethering, and price.Â
The new iPad is a modest revolutionary upgrade, that is why it is called iPad not iPad3 because it is for the majority of people who want to buy their first iPad.
I will show you the difference and similarities of iPad,iPad 2 and iPad 3.
Difference/Similarities      iPad                 iPad 2                                 iPad 3
1.Processor    1 GHZ Apple A4       1 GHz dual core apple A5 ( 2x clock speed , 9x GPU speed)   A5XSoC  Â
2. RAM           256 Mb                    512 Mb        1 GB      Â
3. Weight        1.66 lbs. (wi-fi+3G)   1.35 lbs(wi-fi+3G)                                  660 g( 4G LTE)
4. Camera      no  camera        rear support (720p HD +video recording)     front and rear megapixel 1080p video
5. Internal Memory   16Gb/32Gb/64Gb 16GB/32Gb/64Gb                     16Gb/32Gb/64Gb
I think this is the important features, for more details just refer here
The iPad 2 and iPad 3 look so similar, the only real difference is the lack of a button on the front of the iPad 3 and that it's a bit thicker and heavier, otherwise they share the same iconic iPad design and if you put them next to each other you might think at a glance you were looking at the same product.
To compare the two, I will highlight the main features of configuration;
Hardware
Apple's iPad 2 has dual core setup with a 1GHz ARM Cortex-A9 processor on the company's own A5 chipset, this also uses a PowerVR SGX543MP2 graphics processing unit (GPU) and there's 512MB of RAM built in.
The iPad 3 is built on latest A5X chipset with a quad core graphics processor which makes it super fast.
Display
iPad 3's screen  is 9.7 -inches,but unlike the iPad 2 it has a full size Retina IPS LED-backlit display with a 2048×1536 pixel resolution at 264ppi.
iPad 2 features the same 9.7-inch expanse of LED-backlit IPS glass  with a 1024×768 pixel resolution and a pixel density of 132ppi.
Camera
The iPad 3 has Apple's new iSight camera design, already found in the iPhone 4S, has a 5-megapixel back-light illuminated sensor (BSI) and a five-stage lens. It has excellent video and image stabilization, autofocus and auto-exposure control.
Apple's iPad 2 has a very lackluster camera setup at 0.7-megapixels, with a 960 x 720 pixel resolution, 720p video capture and a VGA secondary for FaceTime calls
Summarized comparison of the two is as shown in this image;
