pzar08
Posted on - 08/27/2012
Hi bloggers,
Is there anyone could help me on how to fix my installation of Gist plug-in for my Lotus Notes? After I installed the plug-in I can no longer see any photos in my contact list that is located in every email profile.
Hope to fix this soon… all feedbacks are welcome and well appreciated. Thanks!
Gist Plugin installation on lotus Notes conflicts with contacts photos
When you install both the IBM Connections Status Updates plug-in as well as the IBM Connections Files plug-in for your Notes client, you have to ensure that they are both the same version. In case you are running different versions of this plug-ins together then it is good to know that action is not supported.
In the event that you do an installation of the original 3.0.1 version of the Status Updates plug-in, you will need to ensure that you install the original 3.0.1 version of the Files plug-in.
And if you choose to install the latest 3.0.1 version of the Status Updates plug-in, you will also need to ensure that you install the latest 3.0.1 version of the Files plug-in.
Carl
