Give a brief account of digital to digital conversion? Please explain
Hi dears,
Give a brief account of digital to digital conversion? Explain each heading or term in a sentence or two (be to the point).
Sincerely,
Ahmad Raza
Hi dears,
Sincerely,
Ahmad Raza
Hi Ahmadraza
This conversion takes place when an analog system is used to exchange between two digital signals. This take place when you first change a digital signal to analog form whereby the analog form is re-encoded digitally, this process helps in the analog filtering techniques to be applied to digital signals.
HI Viewers,
This particular conversion
process occurs whenever a good analog program can be used to change among a pair of online digital signs. This particular occur when you initially modify an
electronic sign in order to analog type where this analog type is actually re-encoded
electronically, this method allows within the analog blocking processes to be
used in order to online digital signs.
Hellow Ahmadraza,
I am describing you about the digital-to-digital conversion .
Regards
Shifflett LaurelÂ
