Give me advice for doing dr fix outlook
I find an error process while making daily schedule in Ms Outlook, and I want to fix it. Please give me advice for dr fix outlook.
If you made any changes to the default settings of outlook, change them back. If you are not able to change them back then reinstall the software.
After reinstalling the software, follow the steps below to create daily schedule using outlook:
1. In outlook you do not need to go to task planner and then assign a task. You can directly go to the calendar and select a day and add a task.
2. You can also add the time and details for a specific task. See the screenshot below:
3. You can add any number of tasks to a day.
Hope this information helps you.
