Give me alternatives application ava find similar
I know that AVA find is almost the best for input manual database of number or words, but its quite expensive. any substitution ava find similar ?
There are similar software available that work the same way as AVA find. They are readily available online for free downloads and depending on your work load it would be easy for you to identify the one that best suits your needs. I can suggest a couple of them;
Task Tracker – It searches for files fast, you can be able to open, rename & move files. Also sorting of files and organizing of files into various folders is easy therefore makes work easier.
SearchMyFiles – It allows you to search files using many attributes of the files for easier location. You can such by name, date created, date modified, file content, file size just to name a few. It also has the advantage of being used anywhere not only your PC as it is portable, you can use it from an external storage device like a USB drive or Memory card.
Power Search – It allows you to search files that are archived such that you can even find files that are hidden inside the visible files.
Instant File Name Search – Its a unique search tool that allows you to use Boolean operators to search files and organize your database saving time and money.
They are compatible with any Windows platform, easy to use and free downloads available for users. Hope that helps.
