Give me more than one alternative windows audio mixer
The windows audio mixer is good but I need another application with more feature.
There are many choices of audio mixer editor in the market.
Give me more than one alternative windows audio mixer .
Answered By 0 points N/A #151943
Here is the alternative Windows Audio Mixer
  • Power Mixer 2.7
A competent audio mixer restores the typical Windows level control. It presents the audio mixer; a scheduler, adaptable presets, and control line support. Currently you can manage sound with your mouse or with scorching keys.
  • DB Audio Mixer and Editor 1.00
An editor for visual audio files for music and sound recording, mixing editing, playing, format conversion and pertains a variety of audio filters and effects.
  • Xilisoft Audio Maker 6.3.0.0805
An audio conversion certified, CD burning and slitting. Permits to process the component of the file alter output parameter and include audio effects.
Best regards,
Heather marie
Answered By 590495 points N/A #282595
If you are looking for a good replacement for the standard Windows mixer, you probably want to try Power Mixer. It is an advanced Windows audio mixer that can be a perfect complete replacement for the standard Windows volume control. It allows you to easily change the volume by simply rotating the mouse wheel or using the keyboard hotkeys.
power-mixer
Power Mixer includes an audio mixer with advanced volume controls support, an on-screen display, command line support, a scheduler, and can store and recall various unlimited presets through one-mouse click or via system-wide hotkeys. Go to Actual Solution – Power Mixer to download. It supports all versions of Microsoft Windows from Windows XP and earlier up to Windows 10.
If your operating system is Windows XP or older, select the “Windows XP and lower” tab for the download. For Windows Vista and higher, select the “Windows Vista and higher” tab. This is a free trial download. The download is a fully functional application that can be used without limitations for up to 14 days.
At the end of the trial, you need to register your copy to unlock the software and continue using it without reinstalling or uninstall the program from your computer if you don’t want to register.
