Hi, I have to know about some stereo vision. First can you give me one ni stereo vision example to know about it? Because I need to do some NI stereo vision development module. If possible please help me to go on. Thank you.
Give me one ni stereo vision example to know about it
Stereo Vision or stereoscopic vision means that you can see an object with both eyes on the same place which gives you depth perception.
This allows us to see special 2 dimensional images and movies which gives the appearance of 3 dimensions.
A very well known example of this is the movie Avatar.
This image is an example of how the brain processes the image which allows us to see 3 dimensions.
This is an example of an anaglyph image. You need special glasses made of one lens cyan color and one lens magenta color to see the 3 dimensional effect.
To find out more information about stereo vision there are quite a few indepth articles here and Stereoscopic Vision here
Here is also a video which will give you an example of how stereo vision works.
