Give me suggestion bitdefender 9
Hello guys,
I am here to ask some help form you. I need some information about bitdefender professional 9. I heard that it slows down pc as it consumes a great memory while it is running. But I do not have concrete information on it. So if you guys know about it and its performance then please answer here. Thanks in advance.
Best Answer by Flinder Matthew
Answered By 0 points N/A #193921
Hi there,
          There are lots of good anti-virus software out there that you can find, but if you want a Bitdefender, here are some information about it. There is a latest version of Bitdefender is it the Bitdefender Total Security 2013 and also the Bitdefender Internet Security 2013. This anti-virus provides protections from e-threats and also online banking attacks. It also protects mobile phones from theft or loss; it provides automatic back up for files. It also optimizes the speed of your PC and its performance. Hope this helps.
Answered By 20 points N/A #193922
Hi Christopher A hopkins
Hope you are enjoying your life.
By reading your post, i found that your are looking for best antivirus software with greater efficiency and optimization.
So far, Bitdefender is a good antivirus software.It provides real time security for your pc.
Download it from cnet.com. It's good and reliable.Regularly check the C drive registry and update the scan progress.I will recommend it.
Thanx.
