Give Proper Description To Call To Dll Register Server Failed With Error Code 0x80004005 Remove Bug
When I have tried to install adobe in my computer system. I received an error message call to dll register server failed with error code 0x80004005. Can you please tell me how to fix it?
Answered By 0 points N/A #290361
To solve the problem we have to follow some steps:
1. Firstly, Go to start button> all programs > accessories, then go to next step.
2. Open cmd > select run as Administrator > authenticate.
3. If command prompt work and read C:\ Windows\ System32, then move to next step 4 and if not, then type this in command prompt cd %system root%\ System32.
4. Type regsvr32jscript.dll.
5. You received an dialogue box with message server succeeded
Answered By 590495 points N/A #320642
That error points to a failed DLL registration or when you are installing the program, setup failed to register a particular DLL file. If you are installing an Adobe application, check the system requirements again and make sure your computer meets those requirements. Also, when installing the program, make sure you are using an administrator account.
Installing programs with limited accounts or non-admin user accounts normally end up with a failed installation. Shift to your administrator account and install the program again. If you don’t have an admin account, ask someone with an administrator account on the computer or your network administrator to install the program for you. This should fix the problem.
