Give Simple Steps To Restart A Laptop.
I have installed an anti-virus program on my laptop, and it requires me to restart the laptop for completing the installation process. How can I restart my laptop? Thanks.
Various software require you to reboot your computer for completing the installation process. For restarting your computer, follow the steps mentioned below. From the Start menu, click on Turn off computer. Click on Restart.
On Windows 8 and above, click on Power options icon after clicking on Start menu and choose the Restart option.
Alternatively, you can also press Ctrl+ Alt+Del simultaneously.The Windows Task Manager window will be displayed. Choose Restart.
Your laptop will restart and be rebooted.
