Hi friends,
I am stuck up at Glary registry repair activation process. I have installed Glary registry repair software, but can't complete the activation process. It fails to complete the activation registry. I am using windows 7 on my HP pavilion 6 series laptop. How to overcome the error and get activated.
Thanks,
Robert B Guy
There can be several problems with the activation process.
– You should have the last version of the software.
– You should buy the software.
If you have last version and you bought the software then you need to run it for your version of Windows.
If your license has expired and you bought a new one, you need to wait for the activation process (1-2 hours)
If it's still not working, you need to contact support at e-mail:Â [email protected]
Maybe you want to try some other programs like CCleaner – CCleaner is one of the best free for use tool for cleaning your Windows PC
