Globetrotter Mac problem need a solution
I updated my MacBook pro now i have Globetrotter mac problem. I want to access  Glob Trotter Application it crashes and will not load. Please suggest me the best solution for my problem.
Hallo Lane,
Maybe the Glob trotter application needs updating too. After updating your MacBook there might have been compatibility issues that arose. Possibly the version you updated to needs an updated version of Glob trotter application and therefore you will need to update it and see if that will resolve the issue.
Nicke
If the software crashes and does not load after installing it on your Mac PC, it is a sign of an incompatible application. The compatibility of software to work and run on a computer depends on its required system specifications. It should match the system running on your machine because if not you will surely have problems like this one right now. To avoid experiencing this kind of problem with the software you are planning to use, be sure to check the product’s system requirements to immediately know if it’ll work on your computer or not.
In your case, if the software was downloaded from the web, try visiting the website again where you exactly downloaded it then check for the application’s system information or system requirements. This will tell you if the product is not designed for your operating system. If this would be the case, the only solution is to find another version that is compatible with your Mac PC.
