A Williams
30 points
Posted on - 09/26/2012
I used Glympse for sharing my location with my family and friends. It works fine on the previous iOS version but after updating my iPhone to iOS 6, it started to crash randomly. I wish I could just revert to the old iOS 5 but Apple is insisting for an update when there is an available update. How can I fix this?
Glympse keep crashing after updating to iOS 6
iOS 6 altered several things on how contacts work. The developer of Glympse did not update the application to suit iOS 6 beta. Hence, the changes on iOS affect older version of Glympse and resulted in instability. To fix this, simply download the new version of Glympse for iOS. Get the latest version on https://www.glympse.com/get-glympse.
Hi A Williams,
You can recover the data due to the crash of iOS 6 software.
The steps to recover the lost data are as follows:
1) Download the recovery software from the mac official website
2) Install the downloaded software in the system
3) Select the backup of your device and select 'Start Scan' button
4) You can select the files you want to recover from the system
5) Click 'Recover' button to recover all the affected files in the system
6) Now you can install any version of iOS in the phone
