Gmail is not accepting my password
Gmail is not accepting my password when trying to retrieve my email with POP.
I entered the correct password and yet, it keeps asking for my Gmail password.
What should I do?
What should I do?
My dear friend you will have to justify your bare in total point here:
Explain in detail please:
Which operating system you are using (windows or Linux)
Show and type you use to operation Gmail (IE 9 or Outlook 2003)
Which antivirus you have installed or (Norton 2007 or Microsoft Internet Security Essentials)
Any extensions, toolbars or plug-ins:
Then it will be easy for me and for others to cover this problem.
Thanks
It's a common problem for Gmail users. Here are two ways the problem can be solved:
Now Sign in normally.
Dear friend,
There could be several issues while entering password:
1. As you know passwords are case sensitive and hence you should check if your caps are on or not.
2. If there's no problem with case sensitiveness please report the problem with gmail because sometimes it happens with gmail and hence gmail will provide you with options to go for new password, and that will surely solver your problem all you need to do is to click on forgot password option in gmail and follow the steps.
Your awesome Alrafa! I never thought that Gmail has an additional verification step.
I followed your steps, I am very thankful that you included pictures in the steps.
I can no access my Gmail account.
Thanks
Hi Arthur Almanza
As well these solutions also check out another Techyv post which is addressed your problem. Hit the below link and get more idea to fix this issue.
