Gmail Notifier Pro 4.2 support
Gmail notifier is excellent internet software to monitor my Gmail inbox. I’m curious about the new version Gmail Notifier Pro 4.2. Can multiple Gmail accounts be checked at a time using this software?
Gwendolynhunterr
I agree with you. The Gmail Notifier Pro is a very good windows application, and YES, it has the capability of checking MULTIPLE Gmail accounts, and provides the notifications for any new mail.
Of course it has very easy to use features and settings.
·        It has very easy to use settings and features and easy to install
·        IT HAS THE CAPABILITY TO CHECK MULTIPLE GMAIL ACCOUNTS
·        Write and reply to the mail without opening of the browser
·        Schedules can be defined when to check the mails
·        For the tech guys, it also support Atom and IMAp protocols
·        Most important, its portable version can perform from a USB / Flash disk
·        And most of all, carries all the security features of Gmail itself.
So your basic question, it does support multiple Gmail accounts.
PT
If you are referring to the Gmail Notifier Pro for Windows from gmailnotifier.se, it does support multiple Gmail accounts. So, if you have multiple Gmail accounts, you won’t have any problem adding them to Gmail Notifier Pro. If you are using Gmail Notifier Pro 4.2, you probably want to upgrade to the latest Gmail Notifier Pro 5.3.4. Go to Gmail Notifier Pro for Windows to download.
It supports Windows XP, Windows Vista, Windows 7, Windows 8, and Windows 10 both 32-bit and 64-bit. Gmail Notifier Pro requires .NET Framework 3.5 as prerequisite. If you are using Microsoft Windows 7, you don’t need to download this because .NET Framework 3.5 is included in Windows 7. But if you are using a different operating system, you need to download and install it separately.
Head down to Microsoft .NET Framework 3.5 SP1 to download. If you have Gmail Notifier Pro, you don’t need to actually install an email client because this application can already be used as an email client. It includes support for all common message operations such as send email, reply, preview, save attachments, delete messages, and read messages.
It is a good alternative to Microsoft Office Outlook and Mozilla Thunderbird. It also includes pre-configured settings for all major email service providers allowing you to easily get started.
