Clark Orcus
20 points
Posted on - 03/09/2012
I have been using g-mail for a while now. My internet connection is little slow but so far it was working properly. Recently it is showing some errors and suggestiing to use basic HTML . I do not understand the problem and asking assistance. Please someone kindly notify me whether this is a connection or problem or something else.
Clark Orcus
Gmail is running slow on-connection problem or else
Hi Clark,
There are different reasons why Gmail is running slow. Yes, others have also the same experiences and tried with these solutions:
Try to look into the cause of slowing connection in opening Gmail, one of its reasons is that you may have enabled many Gmail Labs. If so, enable only features that you need. Another reason is that you might have been using browser with extensions and plug-ins, try to disable the plug ins and extensions. HTML Mode is faster but its features are not as fine. You are also sacrificing AJAX-driven features and niceties.
However, you can use a helpful add-ons which is chrome-Gmail Checker plus. Try, browsing Gmail with it you may like it.
