jhonny jack
30 points
Posted on - 01/03/2013
Hello everyone here,
Today I am here with a critical problem. In my Gmer I am facing the following error, It took at the time of the application’s getting started.
It also occurred while scanning and even in safe mode.
Here is the error message.
GMER
C:Windowssystem32configsystem: The system cannot find the file specified.
Any idea? Please help.
GMER – The system cannot find the file specified.
Maybe you are running the 64-bit Windows version. GMER doesn’t work on that particular version. Use a 32-bit Windows version if you still want to use GMER. If you can’t do that, what I can suggest you is to get another program. This is a common problem among 64-bit users since anti-malware tools and scanners have a problem connecting to these type of Windows version.
