GoldMine installation file error while creating workstation on Windows 7 ultimate
Hi
I will certainly help you to solve your problem. To solve GoldMine problem, before installation go to Control Panel, then Network and Sharing Center. Click on see Full Map. If it says off then enable it. Then start Group Policy Editor as administrator and go to Administrative tools and enable Mapping. Then install. It will install normally.
Hello Brady,
There must have been a problem with the GoldMine installation setup that you used, and therefore to resolve the issue that you are getting you will need to do the following:
Nicke
Thanks both of you for your recommendations. Emil Onoon, your system is easy. I have followed your step by step instructions and I am amazed that I have overcome the problem now. Well done Emil Onoon and thanks to you and Techyv.com for helping me.
