Goldwave 5.57 can’t open MP3 files
40 points
Posted on - 02/19/2012
Hello, experts!
I am a PC user with Windows 7 32-bit OS. I am currently using Goldwave 5.57 to keep files in MP3 format. However, an error message keeps appearing whenever I try to open the same MP3 files. The pop up window says:
"The program can't start because MFPlat.DLL is missing from your computer. Try reinstalling the program to fix this problem."
I relocated the LAME encoder files in the ~Program FilesGoldwave folder but nothing happened.
Can you, guys, help me? Thanks in advance.
