GOM Player Stopped Working Correctly when Playing Videos
I am having problem with my GOM Player when I try to play some videos.
The error message says 'A problem caused the program to stop working correctly.
Your current GOM player has stopped working properly as the program files might be corrupted.
To solve the problem, try to download a newer version of GOM Media Player.It's available and you can get it free from
This link http://player.gomlab.com/eng/download/. Then, uninstall your old version and install the new one.
You can now play your videos.
Hello
The problem can be a number of different reasons such as the video you are trying to play can be corrupted or it's missing a few frames in the video file which can also cause stability issues. It could also be that the format of that particular video is not supported.
I would rather recommend you use VLC player. It is free and very stable. You also do not need to install any additional codec packs to play the videos. It has a lot of features and can play some video files that are corrupted and has the ability to repair most of them.
